Here are the basic Schneider cams that are out there.
http://schneidercams.com/solidfollowercamshafts-2.aspxhttp://schneidercams.com/hydraulicfollowercamshafts-2.aspxAs far as posting up a pile of cams its really not going to help as much as just calculating what you are thinking of running.
The stock 2.6 liter cam yields about .390" lift with the stock 1.4 rocker. If you divide .390" by 1.4 you will get the cam lobe lift of .278" ~.279". Now when you put the 1.6 roller rocker on it all you do is multiply the lobe life of .278 by 1.6 and you get .446" lift.
You can do this with any cam as long as you know the cam specs :
Part Number: 14629
Grind Number: 294H-14
Intake Duration (gross): 294
Exhaust Duration (gross): 294
Intake Duration (.050”): 240
Exhaust Duration (.050”): 240
Intake Valve Lift*: .465"
Exhaust Valve Lift*: .465"
Lobe Separation: 114
Intake Valve Lash: .000"
Exhaust Valve Lash: .000"
RPM Range: 3500-7500
*Based on 1.4 Rocker Arm Ratio This is Schneiders 294H cam with a valve lift of .465" using a 1.4 rocker. Divide .465 by 1.4 and you get .332" lobe lift. Then multiply .332" by 1.6 and you get .531" valve lift. I would definitely need to know this when you bought this package because I clearance these retainers for a .500" lift cam and this baby would smash the crap out of your valve seals if I didn't add more clearance for the extra lift.
Part Number: 14626
Grind Number: 264H-14
Intake Duration (gross): 264
Exhaust Duration (gross): 264
Intake Duration (.050”): 210
Exhaust Duration (.050”): 210
Intake Valve Lift*: .434"
Exhaust Valve Lift*: .434"
RPM Range: 2000-6000
*Based on 1.4 Rocker Arm Ratio This is Schneiders 264H cam that has a valve lift of .434" with a 1.4 rocker. Divide .434" by 1.4 and you get .310" lobe lift. Then multiply .310" by 1.6 and you get .496" valve lift. With this cam you would be fine running the lightweight valvetrain package clearanced fora .500" lift cam.
Anyone looking to buy a performance cam can get it directly from Schneider for $118.99 with your cam core to regrind plus shipping.
