Quality replacement clutch line for Starion/Conquest. This line is made from smooth-bore PTFE, covered in a stainless steel braid, allowing for a 3000psi working pressure rating. The PTFE inner core will not expand like rubber, leading to better pedal "feel' and the clear or tinted PVC outer coating ensures that these lines will stay good looking, while easing the cleaning of everyday road grime. Since PTFE is resistant to brake fluid (and most other chemicals) as well as high heat,
PLUS does not crack and age like rubber, you can be sure that these are a lasting upgrade to your car.
These kits are a direct replacement for your old stock lines. Offered in a variety of colored or clear coverings with polished steel fittings, these will fit
EXACTLY like the factory rubber lines. Kit includes bolt and copper washers/gaskets.
GREENavailable as special order.
$30 shippedMost colors of lines are now in stock. All other lines can be ordered with a short lead time.
PayPal and Postal Money Orders accepted. PM or Email for payment info.
Thanks for looking
