I have FINALLY heard back from the manufacturer, and received the pricing breakdown on the previously posted lines
These kits will replace the factory hardline/rubber lines from the oil manifold to the oil cooler and return.
Kit one does so with clear or colored cover on stainless steel braided Teflon -6 line and -6an to banjo fittings on each end, with the appropriate washers and new banjo bolts.
Kit two has the same high quality line, in the same lengths, but with one banjo and one 90 degree -6 crimped on end going to a steel adapter. The ends are "interchangeable" so that you can flip the 90 degree fitting to either the oil cooler end, or the oil manifold end. This also has all the needed bolts and washers
Kit three is once again the same length of high quality line, but with a 90 degree crimped on end at the manifold and cooler ends. Just like the other offerings, all the needed fittings and washers for installation are included.
The regular pricing for these is as follows (in US $). All kits include 48 state shipping:
KIT 1 $155.00
KIT 2 $151.00
KIT 3 $148.00SOME COLORS/KITS ARE IN STOCK. They are available in CLEAR, RED, BLACK, AND BLUE (not pictured, back-ordered at the time of pictures). Banjo fittings in silver or blue.
A Group purchase can be set up for these if there is enough interest. We would need at least 15 orders (regardless of kit or color) to make discounts available.
PayPal and Postal Money Orders accepted.
JR
